Risultati da 11 a 20 di 31
Discussione: Cordino al manubrio?
    Novi Ligure
    Received: 395/6
    Given: 16/1
    Citazione Originariamente Scritto da Bertone Visualizza Messaggio
    Li trovi soprattutto attaccati agli ape hanger delle moto chicano style (ho visto foto e video di road king con rosari lunghissimi al posto del "cordino " in cuoio).
    These are typically called “getback whips,” “mirror whips” or simply “handlebar whips.” They are usually made from braided leather. They are normally attached to the front brake lever, but you will sometimes see riders with one on each side, almost like bicycle handlebar streamers. They are also made in various colors, to match the club colors of the rider’s motorcycle club.
    Origine storica:
    They are ornamental. After WW 1 Cavalry Troopers would have to return their Army horses before returning to civilian life.They kept their leather riding gear including reins and whips. Upon return many bought motorcycles and would adorn them with their leather braids from their previous mount. Thus making it an “Iron Horse” .
    Ma qualcuno dice che:
    Getback whips are not a form of handlebar decoration. They are actually a type of weapon, which the rider will use against a car, which is encroaching on them, especially while they are splitting lanes. The whips are primarily used on car rear view mirrors. They are not lethal, but are considered more of an instrument of terror, in that it may frighten or “wake up” the inattentive driver.
    In many states, the whips are considered illegal equipment, and like a blackjack, may even be considered an illegal weapon. In some states, you can have them on your motorcycle, but they need to be fixed, and not easily removable.
    Forte
    L'avatar di Luca.com
    Received: 270/3
    Sisi.. tutto folklore…
    Io sono stato fermato dai carabinieri che avevo il frustino da cavallo di mia figlia sulla moto (stavo andando al maneggio) e mi hanno fatto una ramanzina perché secondo loro poteva essere arma impropria (). Ho dovuto fargli vedere l’iscrizione alla Fise per giustificare la cosa….
    Chissà se avessero visto il bloster d’acciaio che tengo in macchina…..
    L'avatar di EmmePi
    Received: 1,192/8
    Given: 462/1
    Citazione Originariamente Scritto da Luca.com Visualizza Messaggio
    E che pignoli!
    E l'antenna a frusta delle touring, allora?
    Received: 919/24
    Given: 429/511
    tra il dire e il fare......ci sono di mezzo le FDO
    Moderatore L'avatar di London dude
    Milano/Londra
    Received: 446/3
    Solo l'imbarazzo di dover spiegare che ho customizzato la moto copiando idee di altri prese fuori contesto e fuori tempo per poter dire che la mia moto è xxxxxx (inserire moda a scelta) style mi farebbe desistere da qualunque modifica.
    Nella fattispecie, andare in giro con quello che sembra un serpentaccio di pozzo che penzola dal manubrio sarebbe difficilmente spiegabile anche ai parenti stretti e agli amici più cari.
    L'avatar di Ronfo
    Aosta
    Received: 558/6
    Given: 216/2
    Origine storica:
    Proprio vero che anche i motociclisti come tutti i gruppi umani, ha la categoria cojon.
    Volemose bene, puro spirito Bro
    Va bè io in qualche viaggio porto ben nelle borse la catenazza con lucchettone quindi è reato anche quella?
    Mi pare più pericolosa del tuo frustino.
    Quando ho affittato moto in USA mi hanno sempre dato la catena per legare le moto insieme con gli altri componenti del gruppo e mi hanno anche detto che se ce la facevamo ciul@re senza catena l'assicurazione non avrebbe pagato.
    Received: 270/3
    Mah, io sapevo che ogni attrezzo atto a offendere deve avere una giustificazione per essere portato in giro, quindi la catena sulla moto (come peraltro il mio bloster sulla macchina) possono essere giustificati.
    Piu’ difficile giustificare una frusta su una moto, nel mio caso avevo fornito sufficiente prova del perché la portassi con me e tutto si risolse.
    Un po’ come avere una mazza da baseball in macchina: se sei un giocatore di baseball e lo puoi provare non penso possano dirti nulla, se non lo sei e non hai giustificazioni plausibili rischi di beccarti una denuncia.
    A me lo avevano spiegato così neh
    Piccolo aneddoto: mio fratello fece l'esame di guida per la patente con la panda che mio papà usava anche per andare a caccia, era un lunedì mattina. Salì l'ingegnere della motorizzazione alzando il sedile e sotto il sedile c'era il coltello da caccia di mio padre che si era dimenticato la sera prima.... dovette venire di corsa mio papà con licenza e porto d'armi alla mano per spiegare l'accaduto... (ah, nel baule c'era la cartuccera...)
    Ultima modifica di Luca.com; 16-04-2024 alle 16:10
    L'avatar di Hedonism
    Ravenna
    Received: 58/4
    Given: 19/3
    amici ben introdotti, mi suggeriscono il "mestolo"
    la caratteristica disposizione delle masse, ne facilita il brandirlo ed amplifica l'effetto "frusta"; credo, senza tema di smentiat, chea una sana mestolata in fronte sia molto efficace
    p.s. non credo che se ti trovano un mestolo sul sedile posteriore, abbiano da dire
    Hedonism
    Road Glide '24
    Nos addicted
    Received: 437/0
    Given: 1,745/3
    per la mazza da baseball in macchina ho la giustificazione, mi serve per i raduni
    L'avatar di malvyn
    Foligno
    Received: 88/1
    Given: 12/1
    solitamente le FDO trovano da ridire se uno ha degli oggetti pronti a offendere a portata di mano.
    Se porti nel bagagliaio la frusta a nove code o la mazza da baseball non hanno niente da ridire, mentre se ti trovano un semplice martello sul cruscotto probabilmente ti faranno passare un bel quarto d'ora !
